Hi Micheal and Cmor,
REGAUGING is one of those mystical terms that people use without really knowing what it means. I'm not sure I know what it means either. BUT, Peter Lindemann used the term (speaking at a conference in front of John Bedini) to refer to the capture and then reuse of the same electricity again (more than once and/or over and over). This happens whenever and however we reclaim the electricity that is normally used only once (standard practice).
The quality of electricity, and the terms negative electricity and positive electricity are something else which I for one don't understand?
However, Aaron explained the difference between cold electricity and hot electricity at one conference that made a lot of sense to me. He described cold electricity as current doing work with no voltage and/or voltage doing work with no current. Hot electricity is when both current and voltage are present and doing work, like in a resistor. Watts = Amps x Volts
energy REGAUGED BY THE FIRST SECONDARY BATTERY
In my opinion this is not a matter of regauging, but an issue of the energy being actually converted to something a slightly different form.
