I recently visited Walt Jenkins and was given a demonstration of a 3500 watt gen set running on 95% water and 5% gasoline!!
First we ran it on 22 ml of straight gasoline thru the carburetor. It ran for only 50 seconds no load on that 22 ml and would not restart. Then we put 450 ml of tap water and 22 ml of gasoline in the "Black Box" device which was hooked up to the air intake ahead of the carburetor. Only air, treated water vapors (95%), and gasoline vapors (5%) were entering the engine. It started and ran for a total of 19 minutes with about 15 minutes of that pulling a 1000 watt load of quartz work lights.
The "Black Box" was only drawing 170 ma at 120 vac from a drop cord powered by the grid for 20.4 watts. This was dropped to 24 vac thru a transformer to correct the voltage for input to the "Black Box".
