what I have running right now came from a desire to build something that uses normal current charging along with radiant charging. I wanted a system that would pulse normal current then radiant in alternating pulses. I have used two AA batteries to charge 4 AA batteries a few times now so without hard data (working on an arduino batt logger for hard data) it apears to be a %200 system witch is also backed up by simulations.
In the simulation i used a self triggered relay as the switch and the inductor but in reality I am using a reed switch and a coil running a low friction flywheel with magnets. the way I am using it is this...two run batteries are in series pushing current through an inductor and then through one inverse charge battery (like a tesla switch). because I am using two to one for instance (24v run and 12 volt charge) it leaves one battery of potential accross the coil. the current simultaneously charges the coils inductance and the inverse battery with forward "normal" current. once the switch disconnects the diode allows the coil current to continue to discharge through the inverse battery "radiant" style. in the ciruit simulation you can see that the source ramps upward to the peak then shuts off while the current continues on and ramps down due to the coil inductance...giving the seeming 2 to 1. I have not tried a transistor version or anything other than the reed switch setup I have now but as a stated I have ran it a few times (3-4) and it appears to do just as the simulations show...I charge about twice as many batteries as I am using to run it...sometimes only 3 because of the losses in the motor section. I do know that a voltage on a battery does not prove anything so as I stated I am currently working on an arduino data logger for the batteries so I can track the charge/discharge and also be able to drain the batteries through a known resistance and log that to figure the capacity and get all the hard data...but at the moment I am just able to run it and watch batteries charge...but so far it looks promising and I have never seen a system that used both normal current and the inductive kickback from a coil in one system so i decided to share so all you smart people can make it better or try it out.
