The Laws of Energy
  • The Laws of Energy
    The Laws of Energy
    For the last two centuries the laws of energy and thermodynamics were defined by three distinguished men of science, Rudolf Clausius, Lord Kelvin and Max Planck. The first law of Thermodynamics is defined: “that energy can neither be created nor destroyed.” The second law of Thermodynamics can be summarized by “Simply no perpetual machines allowed” or “The work effect can’t be greater than the energy supplied.”
    This paper explores a different approach to energy and thermodynamics based on the following statements:
    1. All energy has two components: work energy and heat energy
    2. Work and heat are byproducts of the transfer of energy.
    3. Without the transfer of energy there is no transfer of work or heat. .
    4. Work can create heat but heat can’t create work
    One reason for using this approach is to eliminate the confusion of the term “heat” currently used in the discussions of thermodynamics and physics. In most thermodynamics books the term “heat” is used to describe the transfer of energy in two different ways. In half of the book “heat” can be converted to work and later in the book “heat” represents the energy wasted. To eliminate this confusion the terms “heat” and “work” will not be used to describe the transfer of energy but only act as the byproducts of the transfer of energy. One example of this approach is to change the simple statement from “the sun heated the water” to “the sun transferred energy to the water”.
    The following is a step by step approach to this paradigm shift in energy and thermodynamics:
    The complete article with images and calculations can be found at http://www.wrenchtime.com/thermodynamics.html
    Thank you for your comments
    Originally posted by wrenchtime View Post
    The Laws of Energy
    Hi Wrenchtime,
    Yes its a very good article to enlighten about Energy and its differences with Power or Heat per say. However Thermodynamics has its limitations to Define anything more fundamental on Energy. the aritcle still puts the second law of thermodyanmics puts into the correct perspective on the irreversibility between Work and Heat, since is known as Symmetrical gauging in Electrodynamics.
    Electrodynamics shows us that enviromental exchange of Energy due to broken symmetry (an electric dipole) makes Space-time continum to flip their places and actions making Energy and Power interchange their palces as well.
    ''Destruction and Creation if defined correctly makes Energy eternal''
    just the correct way of rephrasing the old second law of Thermodynanics...
