Hi Jules,
Picking up with where we left off in the other thread.
This will work fine for charging a second battery but not for the run battery.
There is a way to "back pop" the run battery, but it requires the coils to be "electrically" separated from the FET and the power coil circuit path. They have to be transformer or "magnetically" coupled instead so they can absorb the collapsing magnetic field and apply it to run battery through a bridge rectifier.
The schematic drawings on page 11 of the JPKBook shows a circuit that both charges another battery and "back pops" the run battery. http://www.free-energy-info.com/Chap...e-fit,-312,842
Failing that I was thinking about charing a capacitor (as in the SG, but using a timer circuit to discharge that every second or so. A mechanical switch will add friction to the rotor and the electronic version could be finely adjustable.
