Originally posted by gravitational_aether
Let's go to the heart of the matter and see what the very pioneers in supersolid science have to say:
Physics - Supersolid Discoverer
Focus: Supersolid Discoverer’s New Experiments Show No Supersolid
Published October 8, 2012 | Physics 5, 111 (2012) | DOI: 10.1103/Physics.5.111
"The first evidence of a superfluidlike state in solid helium came from 2004 experiments that, with improvements, now find no supersolidity."
Even when they thought the helium experiments were demonstrating supersolidity, let's see what they say in regards to what your imaginary difference is between friction and resistance:
Supersolids -- Can Atoms Unify And Flow Without Resistance?
@ALL, PLEASE NOTE THAT THIS REFERENCE ISN'T VALIDATING SUPERSOLIDS, KIM & CHAN ALREADY DISPROVED IT THIS YEAR - BELOW IS JUST AN OLDER STORY WHEN THEY THOUGHT THEY DID HAVE A SUPERSOLID.
Oh, my, what is the title there?
Wait a second, "without resistance"???
And: "Together with post-doctoral associate Eun-Seong Kim, Chan found that when a particular isotope of helium gas has frozen into a crystal at a fraction of a degree above absolute zero, part of it exhibits a property only seen before in superfluids: no friction."
Wait a second, "no friction"???
And: "To understand frictionless flow, says Chan, think of a bunch of kids sitting on a spinning merry-go-round."
Wait a second, "frictionless flow"???
And: "one percent of the solid helium begins to flow without resistance."
Wait a second, "flow without resistance"???
So, it is completely pathological to insist that resistance and friction has a difference. Friction is a resistance and resistance is a friction - it is so much the same in physics that it is even called "FRICTIONAL RESISTANCE". LOL
And your beloved supersolids that are shown to not exist by the very people who claimed they did to begin with (showing intellectual honesty) are 100% equating FRICTIONLESS FLOW AS FLOW WITHOUT RESISTANCE!
Again, one more of your attempts to sprinkle fairy dust in our eyes to make us believe that the two are not the same. Oooohh, oh, oh it's MAGIC!
I'm kidding around so much here because you CANNOT BE TAKEN SERIOUSLY. Your logic and rationalization is an example of pure and simple intellectual dishonesty and these facts you discuss are only figments of your imagination.
The above is NOT open to interpretation - flowing without resistance IS flowing without friction. There are no two ways around it.
One thing you also miss is that even if there is a supersolid, it goes AROUND an object moving through it. The Aether is not just displaced, the Aether can move THROUGH the atomic matrix of the object. There are different dynamics involved that you have yet to consider.
You say it is frictionless and if so, that means that there is no resistance between the mass and the medium it is moving through. Therefore, it does NOT require energy to displace the medium since there is no friction or resistance to overcome.
Force
Frictional resistance to the relative motion of two solid objects is usually proportional to the force which presses the surfaces together as well as the roughness of the surfaces. Since it is the force perpendicular or "normal" to the surfaces which affects the frictional resistance, this force is typically called the "normal force" and designated by N. The frictional resistance force may then be written:
ffriction = μN | μ = coefficient of friction μk = coefficient of kinetic friction μs = coefficient of static friction |
Standard model of friction |
Now, friction/resistance IS a force and if an object moves through a supersolid, even if supersolids existed, the object moves through it without encountering resistance or friction. If there is no resistance or friction, there is no opposing force. If there is no opposing force, THERE IS NO ENERGY REQUIRED since the distance travelled by the mass would be multiplied by ZERO!
WORK (energy required) needed for an object to move against the Aether in gravity for example is W = Fd or Work = Force x distance but we can use the same equation for an object moving through space at constant velocity.
IF THERE IS NO FORCE (FRICTIONAL RESISTANCE) OF AN OBJECT MOVING THROUGH THE AETHER, THEN THE DISTANCE TRAVELLED BY THE MASS THROUGH THE AETHER WILL BE MULTIPLIED BY 0 UNITS OF FORCE MEANING DISTANCE X 0 FORCE = 0 WORK OR 0 JOULES OF ENERGY EXPENDED.
Even if there is 100% recovery, nothing will ever be recovered because nothing was expended to begin with. An object moving at constant velocity through space can move forever since there is no resistance and pretending that it takes energy but recovers energy is a farce.
An object moving at constant velocity through the aether way out in space is in EQUILIBRIUM with the Aether. The Aether is moving through it relatively just like the Aether is moving through us as we stand on the ground. But we are in EQUILIBRIUM with it. There is NO rate of change between the mass and the Aether. Being that an object moving through the aether is in Equilibrium, that means there is NO POTENTIAL DIFFERENCE available for work to be performed to begin with! The potential difference is only there if the object accelerates or decelerates. Then, there is finally energy required to overcome the counter inductive effect and there WILL be a loss.
But at constant velocity where the mass is in equilibrium, there is no potential difference and there is NO ENERGY REQUIRED to displace the Aether. It is in a state of EQUILIBRIUM with it!
Yes, there is an interaction between the mass and the Aether, but interaction does not mean it requires energy. We are standing on the surface of the Earth in a state of equilibrium where there is no potential difference. It does NOT require any energy for us to stand here under the influence of gravity - rebounding Aether pushing us to the ground.
