Hi Guys .
Well I have been at this for 3 years now and have successfully constructed a 6 pole Bedini SSG machine that runs exceptionally well. It charges its own batteries and continues to operate continuously as I swap the batteries around. I find the best results with the cells im using
(Panasonic . model number LC-R121R3P .52AMPS 12VOLT 1.3AH/20HOURS sealed lead acid) to be approx. 5 minutes run time to 15 minutes charge time. 4 cells complete the affair. 3 charging while one runs the system. I have yet to place the device under load but it looks promising as it produces a reasonable amount of torque at 6300 rpm.
And now the question....
Battery switching circuits.
I have looked high and low and gotten ideas on comparators and time based devices and all sorts of paraphernalia but I wont construct them because they require unreasonable amounts of power to operate. Has anyone Any ideas on a time based system?. Or a voltage comparator system that is a workable venture for a 4 battery system?.
I really need help here as I have already exhausted my imagination and Google and need a new direction. Intelligent suggestions are most welcome ..
What I am really looking for is a schematic with labelled components " naturally that would be cherry " If I could be so lucky..
If Mr Bedini is out there monitoring this please help. I'm so close to achieving what you have stated all along. A fully self regulating zero point powered device that runs itself and a load.
If there are any questions you whish to ask me go for it . Ive been at this for a while now and I might be able to help you on your project.
