I don't want to give away your work-around until you officially announce and publicly presented it, but I'm not talking about the current going in one plug and exiting the other in that kind of a loop.
I'm referring to what you posted earlier in the thread around Sep-Nov regarding + in parallel, and - to ground. I'm sure you know the "parallel law" of old electrics - HV for plugs fired in parallel will be same as source for each plug - gap-resistance not, so most RE & current might go to gap with LEAST resistance, according to that "law"... Parallel Firing of Spark gaps has one unique feature in that in Radiant mode the 'Voltage is Split' but with the nature of Current like distribution at each plug, so the more you add spark plugs the more is Splitting/ Additional Plasma burst. in the Conventional senses this would get weaker unlike when you are Radiant mode discharging them. in conventional mode Current is result and Voltage is the Cause. in the Radiant its the reverse but with a Reversed definition:'Voltage Burst is the result of Current mode Geometry'(Parallel)
Does the discharge speed of Murakami Method clocked for HV at 10ns and LV at 100 us by Mark McKay in Gray Replication thread, OVERCOME this?
