Hi Aaron, ![Smile](https://www.energyscienceforum.com/core/images/smilies/smile.png)
I have the "generation 1" fuel injection kit from CB Performance. They are now up to generation 4.
The one I have runs in open loop and the dash mounted module controls the MAP signal to the ECU. The other ECU inputs are engine temp, throttle position, and RPM. There is no oxygen sensor feedback to the ECU. The fuel pressure is regulated mechanically by the manifold pressure. The dash control module has two adjusting knobs, one for low rpm (idle) and one for high rpm (full power). Here's a picture of the 4 generations. The dash module of the one I have is shown on the left as First Gen. I purchased it back in 2001.
Here's a picture of the engine it's installed on.
