I have some strange results to share. I recently built an electronic trigger that uses a Arduino that works as follows.
Arduino receives opto signal from SSG this is received as an interupt, trigger fires on a 20 percent duty cycle. The output from
the Arduino goes to the bases of the MJL21194's. which also includes a potentiometer.
Now for the strange stuff.
Photo 1 shows 'h' wave as produced from electronic trigger
Photo 2 shows 'h' wave + trigger signal
Photo 3 shows DMM reading secondary battery voltage
Photo 4 shows DMM reading 0.0 as the positive probe is disconected
Photo 5 shows DMM reading nearly 2000V with only the negative probe connected.
this does overload the DMM and a '1' is displayed.
This anomaly happens at a certain setting on the potentiometer, as you will see in part 2 I have included further photos from the scope.
