John Bedini No Radiant Energy (Help)
  • John Bedini No Radiant Energy (Help)
    Sorry but not English and I used Google Translate
    Mr. John Bedini took more than two years working his inventions and I spent over 2000 euros to reproduce some of his inventions. I have always defended their work but I am not able to show the Radiant Energy. As you say the Radiant Energy can not be measured with current meters I have used this table https://lh3.googleusercontent.com/-s...COP+Bedini.png Can not get the battery for more power I entered ie if i enter 20 joules load when I put a bulb to get power back to me 20 joules. I miss loads even 14 hours but the results never give me excess energy. I'm just a country boy with no education but I have read all the documents in the Internet as manuals beginner and intermediate I have seen many of your videos Energy From The Vacuum. I look forward to you and I hope you can help me find the Radiant Energy. Thanks for all your work
    Videos on youtube of some replication of John Bedini https://www.youtube.com/user/hackuranio
Name:	2013-07-23 20.14.25.jpg
ID:	51177Click image for larger version
Name:	2013-07-23 20.14.33.jpg
ID:	51178Click image for larger version
Name:	2013-08-06 02.38.30.jpg
ID:	51179Click image for larger version
Name:	2014-02-21 22.24.53.jpg
ID:	51180Click image for larger version
Name:	2014-02-26 18.13.40.jpg
    Sr. John Bedini llevo mas de 2 años trabajando sus inventos y me gastado sobre 2000 euros en reproducir algunos de sus inventos. Siempre he defendido sus trabajos pero no soy capaz de demostrar la Energía Radiante. Como usted dice que la Energía Radiante no se puede medir con los medidores actuales he utilizado esta tabla https://lh3.googleusercontent.com/-s...COP+Bedini.png No consigo que la batería obtenga mas energía de la que he introducido es decir si le meto 20 julios de carga cuando pongo una bombilla para sacar la energía me vuelve a dar 20 julios. He echo cargas incluso de 14 horas pero los resultados nunca me dan exceso de energía. Solo soy un chico de pueblo sin estudios pero me he leído todos los documentos que hay en Internet como los manuales del principiante y del intermedio también he visto muchos de sus videos de Energía From The Vacuum. Tengo mucha ilusión en usted y espero que me puedas ayudarme a encontrar la Energía Radiante. Gracias por todo su trabajo
    Videos en youtube de algunas replicaciones de John Bedini https://www.youtube.com/user/hackuranio
    Las baterias se tienen que acostumbrar a la energia radiante, cuantos ciclos hiciste? puedes probar tambien agregar una bateria mas atras, en vez de cargar 1, carga 2 a la vez y fijate que pasa con la tabla de COP.
    saludos
    Alvaro
    the batteries need to get conditioned by radiant energy, how many cycles did you make? , you could try to add another battery in the back, instead of charge 1 battery, charge 2 and see what happens with the COP table.
    best,
    Alvaro
    Last edited by AlvaroHN; 10-18-2014, 01:25 PM. Reason: Problem with Spanish characters
      Alvaro gracias por la info pero ya he echo por lo menos 100 cargas y descargas o mas. Solo tengo 4 baterias 2 de 65Ah y otras 2 de 7Ah. ¿Si coloco las 2 baterias de 7Ah con una bateria de 65Ah para cargar es decir las 3 a la vez funcionara bien? Lo digo por la diferencia de aperaje o eso da igual. Otra duda ¿Como es mejor colocar las baterias para cargar? En serie o en paralelo. Nuevamente gracias por tu ayuda
      salu2
      saludos
      Alvaro
      best,
      Alvaro
        Las de 65 amperes son de auto? Xq las de auto no son para usar en descarga c20.
        Mas alla de eso puedes tener 7amps en la primaria y cargar otra mas grande, o varias iguales a la primaria. No se la diferencia entre ponerlas en serie o en paralelo. Tendrias que probar.
        En los diagramas de John Bedini generalmente tiene una bateria primaria y dos o mas en la secundaria.
        De todas formas si metes 20 jouls y sacas 20 jouls estas con un cop > 1 , porque tienes q tener en cuenta la energia mecanica del rotor.
        John B pone un ventilador al rotor para demostrarlo... en vez de poner un ventilador habria q poner bobinas generadoras
        Saludos
        Alvaro Hernandorena
          Las baterias de 65Ah son recalgables AGM las de auto ya se que no valen. Cuando empece hace 2 años fueron las primeras que use y siempre pierdes energia ya que no estan preparadas para hacerle descargas de larga duracion. Tambien se que la bateria tiene un COP 1 pero segun John Bedini el saca mas de COP 1 de la bateria o baterias que estan en carga. El tema de la energia mecanica es para el COP del sistema no de la bateria de carga por eso no cuento esa energia cuando cargo la bateria. Segun John la energia mecanica es sobre un 20%.
          salu2
          Saludos
          Alvaro Hernandorena
            Y ya probaste cargar una de 65 Ah usando una de 7 Ah?
            Did you try charge the 65 Ah with the 7 Ah as the primary?
            best
            Alvaro
              Si y la carga sin problemas
              salu2
              best
              Alvaro
                Con esos experimentos pretendes tener una maquina capaz de alimentar tu casa? Hay que entender la tecnologia e ir mas lejos.
                  ingles por favor. con google translate
