Ok after some simple tuning the SG machine is using 1.2Amps (@ 1 pulse per magnet pass) from the Primary battery and the inverted battery is seeing 3.2Amps flow through it into the power winding. It also is running at 1720rpm. That said the secondary capacitor, via the radiant spike of pure potential and the coil collapse is actually supplying 2Amps to the system. Ammeter says it is factual...
I am also not sure if the primary battery is seeing any of the radiant spike... Even though the diode is in place on the primary positive, the spike still may pass right on through until the diode can react to shut it off... This may further compress the wave and reflect it back into the inverted battery. Any thoughts on this?
Anyone else even tried the schematic? If so please let me know what you find out. Thanks. I will post video tomorrow. Tom I will get you some scope shots then as well. Here is a crappy picture of my set up.
-Dave Wing
-Dave Wing
