patent find on magnetic battery
I would say its all the same as Kromry or G-Field Generator , as it speaks about extraction of Magnetic Energy and the extraneous Force required to drive the system is not actually reflected in the out put... for that matter it is also like Tom bearden 's MEG... what say..? the system keeps the Magnetic dipolarity evoked all while supplying energy to a connected load.. a connected load in the G-Field is all that is required to keep the system running, recall that a G-field generator doesn't need torque, it needs Speed, with the heavy flywheel (Watson) it will have a high moment of Inertia and maintain the speed once initiated (Provided a load is always present at the out put). The system raises form a given level of torque depending on how much it is scaled up to... one needs to feed in Pulses of Power (Torque) to get the machine to a speed and shut off once this is done. This is how Watson ..Bedini did it I guess.
Faraday88.Last edited by Faraday88; 12-26-2014, 05:03 AM.'Wisdom comes from living out of the knowledge.'
