I have designed a PCB for the Tri-Symmetrical 3 Battery Tesla Switch V1.0 for the circuit in post #71 http://www.energyscienceforum.com/sh...ll=1#post22331
I have added 3 capacitors, each of the 3 capacitors are connected between each of the 3 battery negatives and the 3 phase bridge rectifier. These 3 capacitors are DC blocking CAPs and make sure only AC can come from the 3 battery negatives.
Copper Side
Composite Drawing
Silkscreen Layer
Drill Guide
Assembly Layer
Parts List
9 x MJL21194 Q1.x - Q3.x
9 x H11D1 P1.x - P3.x
9 x 6 DIN IC Sockets P1.x - P3.x
3 x SBL3040 or SBL3060 Schottky Diodes in a TO-247 package (D1&D2), (D3&D4) & (D5&D6)
6 x 5mm Super Bright Red LEDs LED1 - LED6
3 x 5mm Super Bright Green LEDs R.LED1 - R.LED3
4 x 1000uF/2200uF electrolytic Caps C1 - C4
6 x SB560 Schottky Diodes or Simalar D7 - D12
Here are the PDFs of the Copper Side and the Drill Guide. So it is easier to print to scale.
Drill Guide For (TopLayer,Botto.pdfTopLayer.pdf
I have only just designed this, I haven't made a circuit board from the PCB layout yet. Any feedback on improving the PCB layout is welcome. I was not sure about the size of the pads. If anyone makes this, first check, if I have the MJL21194 footprint is correct. I used the footprint of a TO-247 package.
Enjoy
Most
Kindest
Nityesh Schnaderbeck
Copper Side
Composite Drawing
Silkscreen Layer
Drill Guide
Assembly Layer
Parts List
Enjoy
Most
Kindest
