This thread is Dedicated to the research and development of a Crystal locked timing circuit. To control, The Tri-Symmetrical 3 Battery Tesla Switch, 4 Battery Bedini Tesla Switch or the Ron Cole Bipolar Switch.
I have a Microchip PICKit2, with a PIC16F690 Microprocessor, which I am still learning to program.
With the Tri-Symmetrical 3 Battery Tesla Switch, 4 Battery Bedini Tesla Switch or the Ron Cole Bipolar Switch it takes time for the first set of transistors to turn on, and it takes time for them to turn off and the next set to turn on.
Crystal locked accuracy will be used for timing the Dead zone in real time, so the Dead Zone will be a fixed time delay, that won't vary with frequency, so you are always maximizing on the fastest switching between switching positions(switching between batteries, etc), without the overlaps. Even if the overlap is in microseconds/picoseconds, it will reduce, your switching transients.
The program flow chart for the Tri-Symmetrical 3 Battery Tesla Switch, is very simple, something like this
Output1 - Dead Zone - Output2 - Dead Zone - Output3 - Dead Zone - Output1, etc
It needs to go a low Frequency like 3Hz to 500hz, I could either use an encoder wheel, (Like the encoder wheel volume control on some stereos), or a potentiometer to control the frequency. It would be good to have a coarse frequency adjustment and a fine frequency adjustment.
The encoder wheel frequency adjustment would be best, and have a switch, to switch between coarse frequency adjustment and fine frequency adjustment.
Most
Kindest
Nityesh Schnaderbeck
Most
Kindest
