Hello All,
I see John Bedini posting about Tom Bearden's special collector and an animation by Jean Louis Naudin at the old icehouse pages.
http://www.icehouse.net/john1/index11.html "98% CU + 2% FE" or "98% AL + 2% FE"
..Also correspondence about it at Tom's website:
...http://www.cheniere.org/correspondence/030304.htm "99% CU + 1% FE"
....Where Tom answers about Relaxation time in his book:
.....http://www.cheniere.org/techpapers/F...993/index.html
and i see this exact alloy wire here:
.http://www.fiskalloy.com/product/c194/ (Awaiting response for ReqForQuote for 20 AWG Alloy Magnet Wire)
..Which i posted an info request about here:
..http://www.energeticforum.com/john-b...fo-please.html
This sounds kind of important because TB, JB, and JLN all posted about this from Tom's book. At the link above to correspondence answer about Relaxation time, Tom says:
Date: Wed, 3 Mar 2004 22:50:59 -0600
Dear Luke,
The simplest way to look at relaxation time is this:
First, suppose the input potential is instantaneously applied across a conducting pair connected to a load, so that a difference of potential exists around the external circuit. The electrons cannot respond immediately, so for just a moment the potential flows freely down the circuit, without any electron current. Then the electrons start to move, overshoot a bit as they accelerate, then oscillate back and forth a bit.
Also, recall that electrons move longitudinal down the wire only with a drift velocity -- typically a few inches per hour. Most of the electron movement is laterally in the wire.
But for all this to get started after that instantaneous application of potential, the time delay occurs -- and a certain measure of that is known as "relaxation time".
Unfortunately, in a copper conductor it is so short a time that essentially one can make little or no use of the fact that the potential energy of the circuit can be freely changed without work (i.e., simply "regauged") while the electrons are not yet moving. So for normal copper conductors, one can forget it for any power applications.
On the other hand, something like an alloy of 1% Fe in the copper, as an allow, has a relaxation time that can reach a millisecond. So that is plenty of time for the potential, moving through space outside the wire, to move an appreciable distance along the wire, changing much of the potential energy of the circuit "for free".
There's plenty of time to switch before the end of the millisecond. So the source of potential can be disconnected and a diode switched across the input in, which will only allow current to flow from the ground side to the "high side". That way, the potential energy than one freely added to the circuit can be used for work, whenever the electrons come "unpinned" and start to move as current. The voltage x the current through the load gives the power in the load. Integrate over time, and that is how much free work in the load one can get, except for paying a little for switching.
Of course there are other ways also to "pin electrons" ... (he does not say how)
Somewhere i read Tom saying he could not obtain this alloy wire mix, but now it is on the market with 98% CU + 2% FE. I will have to call Fisk Alloy during work to get some info.
This has been posted at icehouse since 2001 at least.
.http://jnaudin.free.fr/html/tbfrenrg.htm
...http://jnaudin.free.fr/hep/index.htm
Please advise who is using alloy magnet wire and where they got it. Tom says "Copper wire won't work".
...Thanks
Dear Luke,
...Thanks
