I am basically just thinking of lines of force not being contained but flying off into space (like you see in a picture of a bar magnet) as important to Lenz, I got no real idea. What's worse is I have no clear imagine of how two magnetic fields are interacting (let alone super poles). By this I mean I have seen with my machines narrow coils with fewer winds that are more efficient than larger coils with much greater inductance. How do the gears fit together, real mind bender with something like the presentation ZFM. I need to focus primarily on other things than experimenting now but the two experiments on the back burners are 1) returning to the ZFM to see how to arrange coils (and bifilar coils) 2) discharging a cap into a coil and measuring radiant. I looked again at my spreadsheet and am not sure that improvements in efficiency slow as voltage increases. They may drop off up to about 60-80 volts then hold steady to 240 volts. Need to throw together a joule thief or other transformer and run up to 720V or whatever the cap can handle. Should give me my answer. Tesla wasn't opposed to either high voltage or large coils, might not be the worst direction to move in even if my theory is lacking. As an aside, how could an EMP from hundreds of miles away be expected to do so much damage if the effects weren't OU. Now someone just tell me why they keep blotting out the sun every other day with garbage from planes, again no idea but it seems it has to be some sort of arms race thing likely related to electromagnetic over the horizon effects. Equally likely a low level government regulator decided flouride in jet fuel would prevent cavities in trees and it was adopted world wide without further discussion.
