Hi guys,
so this is my SolidState SG
wire lenght is the recommended lenght of the wheel version
AWG ?!
7x MJL21994
100ohm resistor on the base of each MJL
1N4007 diodes
converted to CPD (cap+pot+diode)
In my case I changed the potentiometer to fixed resistors in series because I was running tests with higher uF caps which were killing my small pots.
I used two 12V 7Ah batteries. Both batteries capacity was measured with CBA IV. Input battery was fully charged with RC1-AU and the output was dischgarged to 10.50V with CBA IV. I ran the test for 3 hours or the input V dropped to 12.06V (50%). Then I discharged the output with CBA to measure how much charged. I measured the input mA with digital multimeter , there might be slight deviation when the DMM was and was not in the circuit.
1. TEST
runtime 3hours
1x 330uF e.l. cap
300Ohm 5W resistance across the cap (100+100+100)
input ~600(650)mA
after 180mins
input battery - 12.05
output battery - 12.42 after 50min rest 12.01
measured capacity - 1.74Ah
2. TEST
1x 470uF 50V e.l.cap
input ~600mA
after 180mins
input battery - 12.06V
output battery - 12.44V after 1+hours rest 11,94V
measured capacity - 1.64Ah
3. TEST
2x 470uF 50V (940uF total) e.l. caps
input ~600mA
after 180mins
input batt 12.09V
output batt 12.39V after 1+hours REST 11.85V
measured capacity - 1.43Ah
The higher the input current the bigger the pulse/spike. With bigger pulse you can charge bigger batteries or really push small ones. There also comes the speed or frequency of the pulses. At 1.5A (2200uF) the 7Ah batt went above 14V very quickly while boiling the electrolyte. WIth 600mA input there was no boiling but slowly climbing Voltage on the output i.e. the battery could absorb the pulse without boiling itself (wasting the energy). Every battery has it's pace or speed of charging.
If I pulled the iron core out it stopped working correctly. I was listening to the pops on the standard battery operated AM radio.
Any comments or suggestions appreciated.
AWG ?!
7x MJL21994
1N4007 diodes
1. TEST
runtime 3hours
1x 330uF e.l. cap
input ~600(650)mA
after 180mins
2. TEST
input ~600mA
after 180mins
3. TEST
input ~600mA
after 180mins
input batt 12.09V
