Originally posted by Faraday88
You have 3 variations of the North - are you going to use one with with 3 different kinds? Or just pick one and have than for all 3 North and compare the results between the 3 kinds?
Your coil winding, the middle one, that is actually how I wound my original trifilars because I thought the recovery winding had to be wound in the opposite direction. I thought I was going to siphon off the back emf into a cap in addition to capturing the inductive spike. I thought that because the old SG drawings show the dot at the bottom of the coil, which I thought it was supposed to mean the recovery winding was in the opposite direction. I asked John and he only said it represented a different phase.
Are you planning on putting those 2 windings in opposite direction in parallel?
Back when he was at the "palace" building, he drew me a diagram in the sand outside the building when were were talking explaining the experiments he did with taking a single winding and winding it in one direction, then he would switch and wind it in other direction, then reversed again and so on. He didn't get into the results or what he was trying to find, just that it was an experiment he did.
Your 3rd winding diagram will not necessarily be like the bifilar pancake coil winding, it will just put those two windings in series. We did that something like 8 times on the generator coil that we had on the machine that Peter demonstrated a few years back at the conference.
Like I mentioned before, there is a way to strengthen the S fields that are already there to make it run faster and with less draw. I might post it here - not sure yet.
