ZFM with R Cole's CEMF Circuit
Hola to all,
During Ron Cole's association with John Bedini a number of very interesting motors and control circuits were produced. This collaboration yielded the BiPolar Switching circuit (depicted in prior post) and other enhancements. One of the enhancements was the adder circuit to collect the "Counter EMF" as described by Cole. A better description may be that the terms are not that well defined. It appears, at least to this writer, that the circuit may just be collecting the extra potential created by the inductive collapse upon the removal of power from the coil circuit before the polarity reversal - correct me if I am wrong here. So, it may not be a true BEMF recycling circuit, but an inductive spike collection method. The semantics here can be rehashed by others and corrected as need be. Of more consequence is the impact on motor performance.
The additional circuit is essentially a diode bridge, whose sole purpose is to collect this collapse of potential during coil power off and to transform it into a usable form that can be injected back into the ZFM's coil power circuit. All in all, an interesting conjecture. Question is whether this does indeed work and, more importantly, can it be used to jack up the performance of the ZFM??
As an example preliminary data from the 4 pole configuration is used:
Series mode w/o Cole circuit
36.26v, 6733 RPM at 0.81A, 000 gr Load with input 29.37w - 00.0% eff
36.83v, 4617 RPM at 1.54A, 540 gr Load with input 56.72w - 28.8% eff
Series mode w/ Cole circuit
36.23v, 7180 RPM at 0.79A, 000 gr Load with input 28.62w - 00.0% eff
36.89v, 4690 RPM at 1.50A, 550 gr Load with input 55.34w - 30.3% eff
In general from multiple readings in Series mode the added Cole circuit yielded about a 10% improvement.
Parallel mode w/o Cole circuit
23.80v, 8340 RPM at 1.46A, 000 gr Load with Input 34.75w - 00.0% eff
24.29v, 4610 RPM at 2.80A, 550 gr Load with input 67.29w - 24.5% eff
Parallel mode w/ Cole circuit
24.39v, 8443 RPM at 1.53A, 000 gr Load with input 37.32w - 00.0% eff
24.29v, 4950 RPM at 2.69A, 550 gr Load with input 65.34w - 27.1% eff
In general from multiple readings in Parallel mode the added Cole circuit yielded about a 10% improvement.
Overall the above experiments were not pushed for more performance and RPM. The last set of experiments were incomplete when a shorted wire from the Cole circuit breadboard fried one set of transistors. This will be repaired and the experiments run again in the future.
It is of interest that in Parallel mode the 2 wire output from the Cole circuit was 2 to 4 volts higher than the combined input voltage from the Bipolar switch - for a 24.5 V power supply voltage, the total coil voltage potential would equal 49.0 volts, but the Cole circuit output would read 52 volts. This split output was fed into the transistors.
BTW the function of the 4uf capacitor in the circuit is to smooth out the voltage speed bumps, I believe that a higher value would provide a bit more smoothing. Not sure what the function of the balance resistor is at this time.
In the next post, as time permits, I intend to more fully describe the performance of the added Cole circuit through a comparison of scope shots with and without the circuit.
Thanks for your attention...
Ciao,
Hola to all,
Ciao,
