Solid State Bedini Switching Circuit
  • Solid State Bedini Switching Circuit
    Background
    I spent some time converting John Bedini’s Battery Switching (BBS) concept from toggle switches or relays to a fully MOSFET controlled circuit. I found the key lies in the use of diodes. MOSFETs only have 3 legs; Gate (control), Source (input), and Drain (output). When the Gate is > Source (N-MOSFET) the Source is connected to the Drain like a relay.
    The BBS places 3 energy storage devices (batteries, capacitors, etc) in a rotation. In one rotation, C1 may have its positive tied to Output Positive (“P”) and its negative tied to C2 Positive (“X”). Later, C1 Negative may be tied to Low (“G”) with its Positive tied to Output Negative (“N”). The complication arises in putting both the Positive of each capacitor in one of 3 places and the Negative in one of 2 places, while connecting the Positive of one to the Negative of another. At any given time, the Negative of one capacitor may be at or above the Positive potential of another cap/battery. Back-feed and cross-feed makes the straight-forward use of MOSFETs impossible.
    To begin, it becomes necessary to map out all possible combinations for both the Positive and Negative connections for each battery/capacitor. Referencing the attached image below, we can call the positive of Batt 1 “P”. The negative of Batt 2 and Batt 3 are “G”. The positive of Batt 3 is “N”. Where 2 batteries are connected in series, we’ll call “x”.
    Since we’re rotating positions of each battery (capacitor), positions “P”, “N”, and “G” will need a MOSFET connection to each of the batteries/caps. In addition, we will need a MOSFET to tie batteries together at position “x”. In reality, position “G” is a negative voltage in reference to output (or even input).
    Connecting the negative side of any of the 3 batteries to “G” requires an N-channel MOSFET. N-MOSFETs are anchored to “ground” through the Source & Drain pins. Whenever the Gate is >0.6 volts (dependent on individual part numbers) of Source, the Drain is connected to Source. In other words, put a positive voltage on Gate, then Source & Drain are shorted together like a relay. That one is rather easy.
    P-channel MOSFETs connect the output to a “positive” source. By lowering the Gate voltage >0.6 volts below the Source potential, the Source & Drain are shorted together. Every connection outside of connecting the Negative side of the batteries to “G” is accomplished with P-MOSFETs!
    Connecting the Positive of one of the batteries to “P” is easy with a P-MOSFET. Connecting the Positive of one of the batteries to “N” is easy with a P-MOSFET. The challenge arises when trying to connect the Negative of Battery 1 to the Positive of Battery 2 using either a P-MOSFET or N-MOSFET. The Gates of unused MOSFETs suddenly start to connect things we didn’t anticipate, or want! That concept is integral to the functionality of the whole Bedini circuit and can’t be skipped over.
    Diodes are like electrical “check valves”. Try to push voltage through them in one direction and they act almost like a dead short. However, reverse the polarity and they act like an open circuit. That electrical principal allows us to make connections between the Negative of one battery to the Positive of another, without triggering unwanted connections elsewhere in the circuit.
    The Circuit
    Referencing the attached schematic, C1 is equivalent to Battery 1, C2 = Battery 2, C3 = Battery 3. Additional components include C4, which is nothing more than a buffer that maintains the power supply during switching; U1 is a 5-volt regulator for a microprocessor; D15 allows an external energy to top off the battery/capacitor system as energy is consumed. D16 allows for an initial charge to the system sufficient to power up a microprocessor.
    The schematic shows a couple of rails; “Rail+” is tied to the Positive side of the load (“P” in the first drawing). “Rail-“ is tied to the Negative side of the load (“N” in the first drawing). “Sys Gnd” is the negative voltage potential, representing the lowest voltage potential in the system (“G” in the first drawing). Sys Gnd = “G”, Vplus = “P”, and “Vgnd” = “N”.
    If you are using a 1.5 volt battery(s) as your energy source with a 5-volt microprocessor, then you can trigger P-MOSFETs directly with your processor. Otherwise, you will need an N-MOSFET to trigger your P-MOSFET’s (not shown in the schematic). Q23, Q24, and Q25 are N-MOSFETs that can be triggered directly by virtually any means (including directly from a microprocessor). The P-MOSFETs will most likely require an N-MOSFET or NPN transistor to trigger them.
    Below is a Truth Table for what is active (=1) or disabled (=0) for each of 3 rotations:
    Rot1 Rot2 Rot3
    C1P 1 0 0
    C2P 0 0 1
    C3P 0 1 0
    C1N 0 0 1
    C2N 0 1 0
    C3N 1 0 0
    C1G 0 1 1
    C2G 1 1 0
    C3G 1 0 1
    C12 1 0 0
    C23 0 0 1
    C31 0 1 0
    In the first drawing we have Batts 1_2_3. For the sake of illustration, let’s call the positions held by those batteries Positions 1_2_3. Rot1 would place C1 in Position 1, C2 in Position 2, and C3 in Position 3. Rot2 drops C1 to Position 2, C2 to Position 3, and C3 to Position 1. Put another way, the Batteries/Capacitors are rotating in a counter-clockwise direction based on the first drawing. This is important if you want to use a 9 volt battery (or 12 volt, or wallwart of whatever voltage) to keep the system charged. D15 allows for that function.
    Circuit Description
    The Bedini Battery Switching principle calls for a rotation of batteries, capacitors, or whatever power storage device, to occupy a position for a period of time, then rotate to a different position. This rotation process allows electrons to be cycled through a load numerous times, thus applying an unpublished nuance of the Laws of Conservation of Energy. Since most of you reading this are already familiar with the Bedini concept, I’ll skip the elementary basics.
    The Truth Table shows what to connect (1) or disconnect (0) to create a connected circuit that resembles image1 in a functional manner; and to be able to rotate batteries or capacitors to other positions within the image1 framework. I used a PIC processor to develop this principle. You may use PICAXE, Audrino, or some other logic controlling type device.
    The critical component is the diodes placed between the capacitor (battery) and MOSFET connections for “x”, which then requires diodes between the Rails and MOSFETs. Reversing diodes won’t work. Placing diodes on the wrong side of MOSFETs won’t work. HOWEVER, what you use for diodes and MOSFETs should be tailored to your application. For diodes, if you have a portable device powered by a 9 volt battery, 1N4001 will probably be all you need. If you have a moderate amp rating, you may need 1N5408. If you are pushing 20+ amps, you may need a bunch of MSCS3460’s. For low amps, N-MOSFETS can be 2N7000’s and P-MOSFETs TP2401’s. Moderate loads; N-MOSFETs = BUZ11, P-MOSFETs = IRF5305…and so forth.
ID:	51470Click image for larger version
    You only fail when you quit!
    Comments? Questions? Observations? Sarcastic remarks?
      Hi Mike,
      I just read quickly through it when you first posted it. Haven't taken the time to really analyze and comment on it yet.
      Sounds like a good idea. Do you actually have this up and working, or is it still in the design stage?
        It's working. I tested an LED with a 470 Ohm resistor. I was getting about 2.5X the work from it (only used 40% of the amps to drive the LED). Stepping it up for heavier loads. Will be testing later this month.
          Hello, Mike, your setup seems very interesting, though your schematic it's very small, and it's not easy to understand. In your schematic, I don't see any voltage sensing, so I assume your setup is time based switching for all 3 configurations of the batteries.
          Could you upload a better picture, please? Some pictures of your setup are, also, welcomed.
          Best regards,
          Teodor.
            Hi Mike,
            Don't know if you've read this thread or not, but I started a thread back in August of 2015 on this same subject here http://www.energyscienceforum.com/showthread.php?t=3079. I switched from solid state to mechanical relay switching. But Nityesh Schnaderbeck jumped in and was able to greatly enhance the basic setup with solid state switching resulting in excellent performance.
            I've since moved on from this to other experiments, but still find the idea fascinating. My latest experiment with the three battery concept uses a "split the negative" approach to run a bicycle wheel SSG that's adding spikes to the charge battery in a four battery rotation scheme where one battery is at rest.
            Best of luck with your experiments! There are a variety of ways to utilize the basic concept!
              Best regards,
              Teodor.
              I found the real challenge was in getting the 3 batteries/capacitors to couple properly using only MOSFETS (could use IGBTs or transistors as well). Whether time or voltage based, the mechanism is what I present. I'm using a PIC processor. In one application I'm tapping the energy source with a PWM signal. I switch every PWM period, thus allowing relatively small capacitors. You could use voltage based switching easily enough.
                Originally posted by mpgmike View Post
                [ATTACH=CONFIG]7337[/ATTACH]
                Thank you for sharing all your good work Mike. I too found your schematic difficult to read and when I blew it up the text became fuzzy and unreadable. Is there a way you can produce a sharper image? It would be much appreciated.
                Richard Gieser
