6 Pole Phase 2
The machine shop came through with the motor parts today. The parts completed were the Timing rotor and the 6 Pole Neo rotor. Tried a dry assembly of the Neo magnet components along with a steel rod through the center of motor rotor as a magnetic assist. All was good until the placement of the last Neo, then the rotor assembly flew apart damaging two of the Neo's and ending up with two groups of high strength Neo's clustered together. Put this on the Not to Do List, for sure. Separating this mess was tedious.
For attaching the Neo's to the Aluminum rotor a Loctite AA 332 adhesive will be used. This works well, the Neo skin fails before the adhesive. Game plan is to assemble the rotor step by step and use my Weber grill to cure the rotor adhesive at 200F, fact of life when the outside ambient is less than 20F. Indoors the odor from this adhesive can be toxic, never mind the smell.
You will note that the Timing rotor has three sets of holes 120 degrees apart for the 1/4"D mini Neo's. In combination with Reed switches spaced 180 degrees apart, the BP switch board will fire every 60 degrees. Of course the appropriate timing Neo's selection must be in place for this to happen. Another obstacle!
Remains to be seen how all this works out - just an experiment with displaced air core coil poles.
Ho! Ho! Ho!
Ho! Ho! Ho!
