Hi guys,
I thought I gave this topic a kick, it's been a while since the last post.
Ok so I am working on a large cap dump setup for the secondary, I want to be able to pulse high capacity caps to the battery, say from 10.000uf to 100.000uf. Been trying to work it out with a 555/opto/2n3440/mj15024. I have been unable to get good switching of the MJ15024 and I'm not really sure why, although it seems the trigger signal to base is to soft I think. So far switching is more like a ramp than a quick discharge.
Then I remembered I had good fun with an arduino board as PWM to control a opto/2n3440/2n6509. With a pot I could easily adjust the frequency of the dump. That worked quite well, but since then I have scaled things up and so things can become more potent, it could be easy to end up frying stuff. I think I will try hooking the pwm signal of the arduino to the base of the 2n3440 which then hopefully drives the MJ15024. If this works it may prove a nice platform for experimenting with cap dumping small or large. Will let you know if progress hits.
One question I have though is this: from the 555 setup you usually get a 50% duty cycle which drives the opto and thus the dumping of the cap. I sort of remember that JB also said that that was our goal to have 50% duty cycle. But does that make sense? I'm trying to understand why you would want a high current impulse followed by spikes. This way we are not converting all energy by way of the cap, since as the transistor is on the cap negative and batt neg are connected and the spikes come through. I may have missed parts here but I have adjusted dump time to 5ms to limit that and get earlier charging of the cap. So very short ontime to only dump the cap then offtime to charge the cap to desired value or time. This is NOT JB's way but appears to charge better?
The frequency of the dump btw can be from 1/2Hz or lower to probably 500Hz but most pratical was around 40Hz. My best charging was seen with more frequent low voltage dumps, but have yet to do the cycles with that.
look forward to your experiences,
floris
floris
