So if that is the case and your running 2500 watts you are twice that. I have just been thinking about how to answer my question as to whether it was really worth it to build a larger multicoil ssg. If I am getting anything close to Ralph's machine then I would say it's worth it. Especially if I use the large comparator circuit. I have improved my comparator ckt with great success and appreciate your input on that. But I still think there are things JB does that go beyond it. Anyway if you have a unit that is 9 times more out than in, it would be reasonable to conclude that there is a cost savings in solar panels. and you would be able to use a smaller tracker or get much more out of a larger one.
However I believe it was John K. that said JB only designed the ten coil for 24volts due to those older batteries and it seemed he was implying we should run these SSG's at 12 volts. that would limit us to the 12 volt units. Not a problem obviously.
Here is another thing I have been considering. Since we have devices in the home that use 2500watts but only for short times such as an electric hot plate etc. I have been thinking of using some of those tractor batteries like the D8 units to supply short term high power. For example take a toaster. It uses quite a bit of power but only for 15 minutes or so. A large set of CCA batteries could handle that with no problem but if you use deep cycle you would have to expend a small fortune.
It just seems to me that with this technology we can get a lot more creative than what I am seeing...
another example is to use our batteries and SSG's in combinations like pumping stations to pump power from one bank to another bank in stages with gain. Alum for the intermediate stages and acid for handling inverters.
Les
