Hi guys. I'm just about to build my first Bedini SSG motor..........i just bought a bicycle wheel off of ebay. The guy said it was alloy but it turns out only the rim is alloy. The spokes are magnetic. Is this a major no no or will it be ok? Thanks
Bedini bicycle wheel material
Marine- John Bedini stated in one of the EFTV videos that the rim was the important part. The spokes can be ferrous, but the rim should be aluminum or some other non-ferrous material. You're good to go. I bought my bike wheel used from a local bicycle repair shop for $5. The bearings were the expensive part. I splurged and went with ceramics. $70 for those but I have not been sorry. The thing has a 18 min 27 second no coil free spin time. Make sure you thoroughly degrease the bearings and then lube them with some sort of PTFE type lube. Tri-flow works well, and lubrilon a.k.a. excelplus are even better if you can find it.
Have fun,
-WoodyLast edited by Woody; 04-10-2013, 05:34 PM."It's not a mutiny if the commander is leading it!" - Wally Schirra, Commander Apollo 7
JB's new bike wheel kits have a steel rim.... when I was assembling it in the shop, he said the steel was fine, it helps the scalar south some..... I have run steel and alloy and nylon rims. I have seen SG machines rotored in an aluminum slug with slots cut out, and many other ways. seems spacing and magnet type are more important. Jb's 10 coil is nylon rimmed skyway bike wheel, single Sg is steel, 6 coil is aluminum......
Hello again guys. I've had to put my build on hold up until now. I'm having a nightmare trying to find c8 grade 3 ferrite/ceramic magnets here in the UK.
I've just gone and bought some of these as the guy on the phone said they are practically no different. Will these be ok? They are 50 x 25 x 10mm thick Y30BH Ferrite Magnet - 1.2kg Pull to be used on a 23" wheel. I have no idea what Y30BH means but the guy says you wont notice any difference?
http://www.first4magnets.com/rectang...2kg-pull-p3531
Welcome Marine,
Go to the Beginners Bedini Monopole forum, much more info there for you. The basic US magnet dimensions and specs for a ceramic magnet are 4.5 lbs (~2kg) pull and 1 7/8" x 7/8" x 3/8" (48mm x 22mm x9mm). These are on the TeslaG site.
Check out part # DM880 here: http://www.duramag.com/materials/cer...-magnet-sizes/ they do not mention the pull.
YaroYaro
Hello Marine,
you are in the UK ?
Great.
I got my magnets from this supplier in Germany :
www.supermagnete.de
Check it out !
