Happy New Year.
I’m rather busy at the moment and can’t be diverted with lots of Qs from your not being able to wait till the Manual is released.
At the moment everything is going well for me to do so on 23rd. If something unexpected happens to change that, like me getting ill, then I will say so, if possible.
I posted plenty of material in the research docs to keep minds occupied
Incidentally, depending on how you plan to mount the coils you might want both in and out leads to be at the same end.
All the edge terminal blocks are 5.0mm pitch (so spanning three holes on the PCB). E.g. H18 is a two pin terminal block inserted over three holes on PCB and missing the middle one. I use just the 2pin type and combine to 4 as required: https://www.ebay.co.uk/itm/234615666086?
The header pins are straight 2 pin, 2.54mm spacing and so for example, H20 will be inserted into both holes as a test point. I strongly suggest you wait for the detail before filling in gaps with some guesswork. https://www.ebay.co.uk/itm/265539912049?
There will be a couple of additional components in the list for the PCB, namely mounts for easy active device switching.
Julian
Julian
