Hy guys i finished building both circuits posted here,Ron Chase one,and RS's.First i did Ron's circuit and seems to work well,the''problem'' being that when i tuned the 25k pot the voltage on the cap varied just a little,15v-15.40v.I used a ss bedini coil and a when i turned the coil pot the cap charged way past 15v(35v cap).Now i wanna ask you..how the dump led should blink?my ss coil stays in the khz range so the led is mostly on but turns of when i decrease the 25k pot res.
The RS circuit worked too,alowed the dump voltage to be adjusted,,charges the batt,but the main issue is that the bd transistor gets hot in minutes because the colector conects strait to the bridge output,when i conect it after the 2.2k it doesnt get hot and the coil buzz turned into pulses as i adjust the 100k pot,and i think the 12v zenner should be 15v because i want to charge the batt past 12v....so both are good in a way,and i cannot decide which to each...
