Hi Rodolphe,
It handles mode 3 just fine and charges faster than mode 2.
As I understand it, the faster the switching speed (both on and off) of the transistor and/or the capture diode the higher the potential of the spike can go. The spike will go as high as it can depending on the load impedance of the battery and associated wiring. The load becomes the limiting factor of the spike voltage.
The 72.28 amps is the cap dump current to the charge battery. The high voltage, low current reference was only to the capture diodes as regards their forward voltage drop being slightly higher for the faster switching diodes. The faster switching speed will more than make up for the slightly greater (.7) forward voltage drop when capturing high voltage, low current spikes.
I'm just guessing here that the clamping diodes faster switching and higher forward drop causes the transistor to switch off faster and limit the total current draw to a lower value. Slightly reducing the resistance of the base trigger pot should bring the current draw back up. ..............Interesting that this did not increase the COP.
I did this on both my attraction (switched reluctance) motor and the wheel driving my two stage mechanical oscillator. These are different type machines with a different type load so I can't really compare them. I also modified my first SSG (which never did over a .8 COP) with adjustable hall switching, but still using the MJL21194 transistors. I don't think that increased the COP much on that machine.
No. I do not have the extended license. I have an older CBA3 unit with the standard license that came with it.
Gary Hammond,
Just a theoretical (since I’m not going to use it now) question on mode 3 (C.G. mode + cap pulser):
For the Cap pulser that we both build*, can that circuit handle mode 3? In other words; would no components be overloaded when the coil discharges right at the moment when the cap discharges as well? I assume it can handle mode 3 since it can also handle mode 2, but just wanted to double check.
Would it be more correct to say: The height of the spike is determined by the speed the Transistor can shut off (and the speed with which the magnetic field can collapse based on the inductance of the medium, iron in our case), the speed with which the diode can switch on determines how much of that spike is being caught.
If I read on the top of page 30 of the advanced manual, Peter calculates pulses of 72.28 amps to the output battery (based on his scope screenshot from page 29). That is a high number (however average amperage on the output 0.7amp.)
Do you have an explanation why this is so; that the amp draw went down (and the charge time increased, so same COP? It’s like these UF4007 have the same effect as if I’d increased the base resistance… If the just the amp draw would have gone down, without the increase in charge time, the COP would have improved, which was what I hoped for.
So with FETs (faster switching) and the hall sensor (adjustable timing on trigger circuit), you say you got better result? More than COP 1.25 which you got on the SG with MJLs?
This is also what Paul said in his video, I’ll post the links we’ve been talking about here too so others have access to it:
p.s. For the CBA software you use, do you have the "extended sofware licence"m with the extra features by any chance?
Gary Hammond,
