Hi Gary, RS,
Test results 24Ah Lead Acid @ input
I finished a couple of cycles with the 24Ah Lead Acid at the input, see attachment. As a comparison I put another test cycle set there as well with different input.
If I had to draw a conclusion based on what I see in those two sets I’d say: All the named parameters do not have a significant impact (yet), that is:
-24Ah Lead Acid vs 12Ah AGM battery at input
-20magnets vs 24magnets rotor
-8 power windings vs 7 power windings
-1.8A input vs 2.4A input
So I’d say at this moment the bottle neck is still somewhere else.
Scope results
See attachment. Since I wasn’t sure how far to zoom in / at which level you can call the signal “synchrone enough”, I just zoomed x200. This is done in Radiant mode. If the transistor switching looks “synchrone enough” to you, then this is not the bottle neck either and will continue building a new rotor with 22mm wide magnets and after that another one with 25mm wide magnets.
Thanks Gary for spending so much time watching those DVDs again to help me. Hope to do some more watching tomorrow and will respond if something catches my eye.
Looking forward to your input based on the above.
Best regards,
Rodolphe
2020-09-01 - Attachment.pdf
Scope results
Best regards,
Rodolphe
