Hi all, ![Smile](https://www.energyscienceforum.com/core/images/smilies/smile.png)
I've had my latest SSG build up to the intermediate book level for some time, and am now starting on the advanced book build. I managed to blow a FET in my 555 based cap discharge I built from the intermediate book schematic, so now plan to build the circuit so generously posted by Nityesh Schnaderbeck. THANKS NITYESH !
I've mostly been charging with it in common ground mode and was able to get it over unity that way running in the 230 to 265 RPM range at 1.6 to 1.8 amps input with about a 3/8" air gap not using the cap discharge. And in the radiant mode it was pulling about 1.0 to 1.2 amps at an RPM from 168 to 180 and double pulsing. If I mechanically speeded it up it would single pulse in radiant mode at 315 to 335 RPM only pulling around 800ma, but the charging was slower that way.
Today I temporarily installed a pot and started adjusting the air gap trying to get the RPM's up to the 370 range like Peter did. And even though I left the 21 magnets on the wheel, I was still able to get it up to 375 RPM by reducing the air gap to 1/8" and increasing the common base resistor from 12 ohms to 40 ohms. And like Peter's demo model, I have to short out the resistor to get it to shift from double pulse to single pulse. The current draw was 900 to 1000 ma and the charging is slower than when double pulsing at a lower speed.
Now I need to order some 16awg wire and build the wide genny coil. That and build a new cap pulser.
I've also been experimenting with a large genny coil directly below the main coil with a small air gap between the cores. It puts out the same wave form as the main coil and will light a string of LEDs with no apparent load on the main coil output, the input, or the RPM.
