bedini sg results
  • bedini sg results
    Hi to every body. I´m new with this topic, I´ve been reading from internet on different kinds of devices to produce free energy from the vacumm but nothing is reveal in videos, forums............... except, as i can see, the bedini experiments.
    Can any of you tell me how to meassure the bedini sg, the one with 8 wires twisted together?. A friend from my country told me that this is not meassureble couse "plasma energy cant be meassure with conventional machines". Is there no way to measure the excess of energy obtain with this bedini sg?. I imagine that one way to know the results of my answer is to know about how long the batteries takes to be fill. Is this correct?.
    How many car batteries can add to this bedini sg with 8 wires?
    Thank you very much and sorry for my english
    You cannot hook a meter to the output to see what you get out of it.
    You have to send the output to a battery so the battery chemistry will convert the radiant energy into a potential difference where you can get more work out of it than you can calculate directly with meters. The battery is necessary to see the extra energy. You have to do load tests on that recovery battery to see how many watt seconds of real work you actually get out of it until it gets down to where it was before you started charging it. That is how you see what you really got out of the system.
    Also, you can measure the mechanical energy of the wheel.
      Aaron, as it is known upto date, which is the maximun mechanical energy I can get from a system like this?. And the watts of real work?. How many car batteries can add to this bedini sg with 8 wires?
      Have any of you tested the device?
      I mean the one with 8 wires I said before.
      thanks a lot
        thanks a lot
        The SG kit or the build recommended in the book will give you close to 30% in mechanical work. The watts depend on the input. I would use one battery on the back for starters - and I'd make it a garden battery.
        I've been observing the tests at John Bedini's shop for this particular kit.
          So if I understand you, you put only a battery to run the system.........how many batteries, of the same kind, should I place to be charged?. Why shouldnt I put car batteries? Could this broke the system if I do?. should I make changes in the system to place car batteries? Sorry for my questions but I need to be sure before I spend my money in a educational device, I need something more effective than this.
          Many thanks Aaron for your patience
            Hi dejorgees,
            The 7 wire single coil Bedin SG device has primary battery and a secondary. The single coil unit would probably not charge 2 car batteries very well. I have used my 7 wire SG to charge a car battery but it takes a while to do it.
            To charge multiple car batteries at once you would need to build an SG with more than one coil. To be honest you will have to scale up. Maybe build a small device with one transistor and learn the basic theory of operation, then build the 7 wire device. I have seen a 6 coil in operation and a 30 coil.
