After reading some stuff on here about stubblefield i decided to put in a copper and stainless rod into the ground spaced about 5m apart connected to some reasonably think copper wires, i connected the iron to the neg of the charge battery and the copper to the collector of a spare switching transistor instead of a coil with the diode output still connected to the charge bat, the input dropped from 665ma to 660ma or thereabouts on a cheap dmm, the battery on the charge side increased bu 0.12 volts instantly
can someone please verify this, it should only take 10 mins to do the copper was a water pipe and the steel was a junk roller from an inkjet
if you need a diagram i can provide but its pretty simple.
