Gen coil spool idea
  • Gen coil spool idea
    I had on hand a length 1x2" hollow rectangular pvc tube.
    I'm using it for gen coil construction to have r60 rods core about the same size and shape as bike wheel mags.
    It can be had at the following link:
    http://www.amazon.com/PVC-Hollow-Rec.../dp/B003Y39WCW
    I've cut out 1/8" spool tops and bottoms and then dremel the slots for the hollow rectangular rod. (anylength!)
    Super glue is stronger than PVC and makes it go together with ease.
    I also have on hand many #18 multi strand coils available to adapt for gen coil use.
    Have one bike wheel setup lovejoyed to a window (modded) motor and can couple my regular bike wheel to my 5 coiler SG. (both have 1/2" shafts)
    Scalin'
    bro d
