During my play time with the timing light experiments as suggested by BobZ the SG was running at a stable level with 6 wires attached to the 8 Trans board. The resistance was being varied with a pot over a narrow range (0 to 43 ohms) to observe the changes to the charging spikes with the timing light. As the resistance was decreased the amperages rose and rpm decreased slowly - this progression had been done several times with the charge amps going up from 0.35 to 0.83, primary from 0.57 to 1.33 and the RPM dropping from 212 to 179. All Good - watching the LED and timing marks. Last run was the kicker!
As the resistance was decreased to ~10 ohms in very fine increments the noise level from the coil increased dramatically and the voltage to the charge battery jumped! The coil produced an abnormally loud level of hum and buzzing - the amperages jumped (increased) on the charge from 0.77 to 1.33 and the primary draw from 1.21 to 1.90 amps. This was very, very unusual...
Foolishly, I assumed that something was wrong and after the data was taken removed the primary power to shutdown. Checked all the connections to the board - all very tight, with one less tight. This setup had been running for at least 4 or 5 prolonged runs. All the other wiring was good.
So what happened here? I have tried a number of times to duplicate this behavior - not happening again. The only thing not tried as yet, is to run with an almost fully topped off charge battery similar to the above test.
In a nutshell, the output of the SG, in an assumed stable configuration, jumped by ~73 percent. Not obsessed with this anomaly, just curious if anyone has seen this in their testing?
Yaro
Yaro
