7812 Connection Diagram Help
In the intermediate manula Page 47, it says the 7812 needs to regulate voltage from the cpacitor to the control section. Is the control section the H11D1 or the MOSFETs? Also, is the grounding pin connecting to H11D1 pin5? When I did it that way, my circuit melted.
Originally posted by Benjamin View PostIn the intermediate manula Page 47, it says the 7812 needs to regulate voltage from the cpacitor to the control section. Is the control section the H11D1 or the MOSFETs? Also, is the grounding pin connecting to H11D1 pin5? When I did it that way, my circuit melted.
By control section in that particular paragraph on page 47 in the book is meant both the Optocoupler + the transistor as they control the opening of the Mosfet's Gate.
The ground of the regulator is connected to the negative of the cap. The output of the regulator supplies 12V to pin5 of the H11D1.
7812 Pin 1 (Input) - to positive of the capacitor and the Battery.
7812 Pin 2 (Ground) - to negative of the capacitor
7812 Pin 3 (Output) - to pin 5 of H11D1
Lman
