Thinking beyond the simple SSG
    the SG circuit and coils as designed are for a maximum 24 volt primary, there are many changes that I do not know of to make it function correctly at higher voltages. coil inductance primarily, and transistor possibly. you will have to do some research.
    I have ran my large SG coil at several voltages up to around 108 volts. It did run a bit (awfully) warm until I removed the smoked neons from the circuit.
    Lately, I've stayed with 24 volts and get spikes in the 100 volt range. (I'll recheck with a scope.)
    I've run the thing up to 20 amps with no heat problems. (22 ga. wire @ 310 feet x 117 strands.)
    I'll take a look and see if there is a difference in radiant spikes at various input voltages.
    glen
