Hi All, After I made the post about the construction pictures of the quad coil I was thinking as to why I wrote the article. It came down to this...I was experimenting with the aluminum quad coil and needed some new info while charging a garden tractor battery. I thought back to some of the DVD's where there was talk of running the ssg on higher voltage. So I fired up the quad coil sitting adjacent to the little coil...both running on 12 volts. The quad coil is not afixed and is loose. Then I thought about 24 volts so I cliped two batteries together in series and and wow did the rpm change abruptly. It sped up from say 140 rpm to around 300 rpm! I thought about the tape holding the magnets at this speed. I ran it for a minute or so and then said what the heck..... lets try 36 volts. I put another battery in series and holly s**t did things go wild! The rpm then took off and my guess is we were running at 400-500 rpm. I thought really seriuously about the tape holding the magnets and had to make a decision weather to run away or try to shut it off while my arm was in the path of the magnets. The machine was not done increasing speed! I was scared! I switched it off and decided that we need to investigate further. I swithched back to 24 volts input and checked the charging battery....it had boiled some of the acid out onto the bench. So I decided to hook a pair of 12 volt garden batteries in series to slow down the charge process to see if I could control things. As I let the quad coil run on 24 volts I noticed that both batteries were boiling and some of the acid was running out of the top and onto the bench. Mind you that the batteries were both cold to touch. This is what led me to believe that I could handle charging those L16's. This the break thru I have been searching for. The higher voltage is where things change dramaticlly.
I have also been knocked down a peg by the awsome power of the negative energy. It is way beyond anything I have experienced before. I have first hand experinece with the destruction that it wields. On some of the larger DC systems and larger control relays I have seen things burn up that just seemed impossible. Now I really get it. The acid batteries thrive on this stuff.
We are not just getting started.....but I want to help others along the way carefully.
I now understand a little more about you John. Thanks
Bud
Bud
