Thought I would write about something new to me but maybe old to you. The trigger circuit alternator. I have rewound all of the 9 lead coils @ 130' long and remounted them to the bike wheel. 16 transistors!
http://i1243.photobucket.com/albums/...ps807e2a13.jpg
I also remounted the 2" X 3" magnets to the wheel 14 pieces in all. I know I am probably going to hear about this but I just have to see what the results are! Anyway so now I have 2 coils mounted so that they are timed for the same magnet passing. I left both coils wound with the trigger circuit and thought I would parallel them together. I got the prototype setup all ready to go and hooked up the charge chords to my 24 volt 720 AH bank.
http://i1243.photobucket.com/albums/...ps17568428.jpg
I hooked up the input side to my big power supply and double checked everything to make sure none of the factory smoke would be released on startup. I flipped on the switch and gave the wheel a spin and started into the voltage slowly. At 6 volts the wheel took off and I hooked up the scope to see what resistance I needed to tune this thing into. At the time I was using a 2.5" dia 50 ohm var resistor to time it in. As I got the resistance set correctly I slowly added the voltage to the SG. I went up to 12volt and let the thing run for a few minutes and after some time noticed something smelled hot. You know that burning smell! I got out my temp gun and check everything on the coils and buss bars and could not find anything warm. I thought it might be the power supply but it was only @ 1 amp. 12v. so I just let it run and slowly added more voltage to it. I did notice that the var resistor windings were red so i found a large resistor and soldered it in.
I later went up to 24 volts and the smell did not go away. Then the wheel slowly ran down on rpm to a stop. I knew something had died!...hopefully not 16 trannies! So I started checking every line and then noticed it. The resistor had come unsoldered. So I resoldered it and fire it back up. @ 24 volts I actually watched the solder melt away from the resistor. OK so I thought the resistor was not big enough. I took 2 more and soldered all three together and @ 24 volts the solder melted away again.
This is when I thought about the alternating current and the rpm of the wheel. So I took a chance and unhooked one of the coils trigger and fired it up again…. Now running on one trigger coil.. Low and behold the resistors ran much cooler. So I let the machine run @ 24volts all night and noticed a voltage rise in the battery bank from 24.8 to 25.2. The next day I noticed the machine had stopped and the resisitor burned into 2 pieces.
http://i1243.photobucket.com/albums/...ps2e863e59.jpg
I then ordered a very large 25 ohm var resistor which is now running the sg.
http://i1243.photobucket.com/albums/...ps444afdf5.jpg
http://i1243.photobucket.com/albums/...ps9705c1d7.jpg
I am now operating @ 30 volts input 2.5 amp with wheel speed of 397 rpm and charging the big bank fairly well considering how massive it is using a 21 ohm resistance on the trigger circuit all 16. Everything is ice cold except for that big var resistor and that part does not mean anything. The heat is excess power that we need to control with the resistor to keep the transistors from burning up.
http://i1243.photobucket.com/albums/...ps11c42aa4.jpg
I would have never guessed that one trigger could provide this much power and could handle this many circuits.....not only that but many more also. I have not studied how much available power is there on the unused trigger circuit on the other coil but the AC voltage output is 20.3~ volts.
http://i1243.photobucket.com/albums/...psc1d02b21.jpg
Probably enough to light a light bulb and possibly enough to rectify and run the machine? Is this what Tom Watson stumbled onto? I am only @ 347 rpm and he was @ somthing like 800 rpm. I am sure there is a very large output at this speed.
Thinking back to the duplicate SG I built not long ago to resemble the one from JB's lab.....the big fan. Just so you all know the fan has a huge purpose!
http://i1243.photobucket.com/albums/...essgflash2.jpg
To govern the wheel speed and keep the trigger resistor cool. I knew for sure JB put it there for a reason and now I really know why!
John knew about this problem long ago and never said anything about it. He outgrew this trigger power problem by switching over to the superpole magnet arrangement. On this setup there is no south pole or very little between the magnets like there is on the regular SG. This brings down alternating current problem and only provides a pulse when needed to fire the transistors. So at the end of the day the regular SG has to be speed limited where the superpole sg does not.
I am fairly sure JB knows just exactly what Tom Watson was up to and why he disappeared for several years. I am also willng to bet he also knows how to make this thing run overunity……and now I am on this path to find out if it is possible. Some of us know about the big DC motors that can run away and self-destruct when the power is shut off. This is overunity working at it’s best but that is water over the dam and no one remembers. These energizers work without the back EMF wrestling match going on and there should be no reason it cannot self run.
Anyway good stuff to think about.
Merry Christmas everyone!
Bud
Bud
