I'm trying to make an SSG with a 9 filar coil consisting of 8, 18awg windings and 1, 20awg winding. I stretched all the wires out to 130' this morning and litzed 'em. It soon became obvious that there was too much wire to fit on the normal 3 1/2" spools we use for these so a question arose in my mind. What is better geometry wise? Taller with the same diameter, wider with the same height, or some ratio of increase to both dimensions? Also, how about the ratio of coil core diameter to coil wire diameter? Any takers on these questions? I cut two of the regular spools and made a longer spool because I have plenty of room to raise my bike wheel to accommodate the height increase. Not so much room width-wise, although I could certainly widen it if need be. Just trying to save some effort on the frame modifications.
Also, since it appears a feller will have to make his own spools as different configurations are attempted, what are some favorite materials some of y'all have used to make your own spools?
Thanks!
-Woody
Thanks!
-Woody
