Hi all!
Did somebody tried following with ssg?
When charged battery is charged fully (like 15 or more Volts) and ssg running then connect the inverter to this battery.
After this, connect conventional charger to the inverter, and charge the power battery. All this should be done when system is running
In theory i suppose second battery should be able to maintain the charge without any high load.
So what i actually try to achieve?
Well i will charge my power battery and in the same time discharge it (i know this actually bad for battery).
In the same time i will charge my secondary battery with high impulse current and then all cycle repeats again.
Which inverter is best for 4,5 Ah battery , i need power draw not higher than C20 rate like 225 mA or 300 mA
I am aware that probably i will take heavy power losses, but i willing to take the risk.
I will try to test it , as soon as my second 20 cycle procedure ends, this is basically my idea, i did not tested it yet, but i hope it have some potential of further research.
