Originally posted by axxelxavier
I'm sure I am misunderstanding your question. My question was, what circuit (ckt) are you using for the "cap dump" to me a "cap dump" is when you use the energizer to charge a capacitor and then take the energy from that capacitor and dump it to a charge battery.
My intuition is telling me that is not what you are talking about.
Are you referring to the cap across the trigger pot as a dump to the transistor base?
your setup seems to be working quite like I would expect from the looks of it.
I notice your pot does not leave you much wiggle room when you get to the audible speed up and the high frequency tone.
try tuning to that point, remove power, measure the ohms on the pot and replace your pot with one that is slightly above that measurement with a higher watt rating.
Also, and maybe before you do that, and maybe you already have - using a larger size cap across the pot could have a stronger effect to your charge battery. Also, I would guess, and maybe others could chime in here, for that thickness of wire, I would increase the length by at least 3x. while you're at it, add another wire along side for 2 transistors and give JB's split the diode method a go.
here is an interesting fact about my setup, it does not charge my 4.5Ah batteries very well, but it charges the life into my 210Ah batteries. So play around with that thought a bit. Hope some of this helps.
kind regards,
Patrick
