recently i made my motor according to bedini motor. but it did not manage to rotate. I speculate my triggered winding is not enough current / voltage to open the transistor gate and make a pulse system....
1. my power winding i use is 1mm diameter and triggered winding 0.5mm .
2. the turns of solenoid is around 600-800 turns
3. magnet that i use is neodymium magnet
4. this is the circuit that i used
https://imageshack.com/i/n64kb6p
this is my motor
https://imageshack.com/i/n8du4mj
this is my solenoid
https://imageshack.com/i/na6vd7j
5. my core is around 2.5 cm in diameter.
6. when is hand rotate, my induced voltage obtained at triggered wire is 50mA -300mA....
7. when is test to switch directly power sourced 12v at power coil, the magnet is manage to repel...
so, when i assembled the circuit, my motor did not rotate AND I TOTALLY STUCK
anyone could help me?? please
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Live Bookmark this Post!Google Bookmark this Post!Yahoo Bookmark this Post! share on MyspaceShare on FacebookTweet this thread
this is my motor
this is my solenoid
