Greetings,
I built a solid state charger for small batteries like AA, AAA, C, D, 9v, 6v, small 12v and I thought I would share the build with the group.
It is wired normally for as an SG circuit except moving the trigger to make it run SS.
I learned how to do that from Patrick’s videos a long time ago and he deserves credit for teaching many of us how to do it, so thanks Patrick you have really shared a lot over the years and it is appreciated.
Some details about the charger:
The diodes are both 1N4007
Transistor is MJL211194
Base resistance is 750 Ohm (two quarter watt 1.5k in parallel)
The pot is about 1k
The wire is 21awg for both 75ft.
The hookup wire is 18Awg braided.
Here is a picture of it.
The first chart is of a 9v Ni-MH. This charge was pulling about 200ma from the primary.
Here is a video I shot while doing these sample runs:
http://1drv.ms/1GGoLtR
Next we have a AA battery. It is a 3000mah 1.2v Ni-MH. This charge pulled about 50ma from the primary.
http://1drv.ms/1kkg65H
I finished up with the 5AH 12v that was the primary in the first two charges, just topping it off. This charge was pulling between 600 – 700 ma from a different primary.
http://1drv.ms/1Pe3zfL
The charger is intended for small loads, versatile enough to charge multiple sizes. Flashlight batteries, meter batteries & stuff like that mostly.
The pot is about 1k
