Originally posted by guyzzemf
just to make sure.
we run of a power supply so input amps and cop are at this point not our main intrest this is a trick for later on the game
if i understand you correctly we tune not for max rpm but for max input amps???? ( hammertime)
i see that we can reach 0.8 amps charge on the single coiler ( with digital multimeter) so far but drop from 350 rpm to 300
resistance is then on the trigger coil down to 30 ohm
at 350 rpm we run at about 70 ohm to 100 ohm depending on charge battery (180AH)
next build is ganna be a 4 coiler for starters
then we have 3 running
regards
weasel
