wheel#1 7 transistor 7 wire 20guage and 23guage matched tip3055 matched 470ohm collector resistors and 1n4007 diodes 1plastic wheelchair wheel
wheel#2 7 transistor 7 wire 20guage and 23guage matched tip3055 matched 220ohm collector resistors and 1n4007 diodes 1plastic wheelchair wheel
wheel#3 7 transistor 7 wire 20guage and 23guage matched MJL21194 matched 470ohm collector resistors and 1n4007 diodes 1plastic wheelchair wheel
I have three wheels ready to sweet spot
The 1k pot has several ranges where the wheels all run.
The 1ohm resistor test under 1 volt has several ranges that pass but the resistor gets warm and even hot so a failure? how hot is hot?
the only way to get the wheel to run with no heat at the 1ohm resistor is to run it at 20milliwatts and the voltage drops to.2volts amazing really amazing but obviously not the sweetest charging spot
The only way to get the two bulb test to light both bulbs is to run the wheel in the generator mode
lost in the either; happiness from Hawaii Jeff Joseph ps.The conference was great. pss. I have a video of the wheel running at 20milliamps on iphone but don't know how to post it here
