My name is Karel and I just finished an other 20 runs with the monopole, last runs with a 4 amp/Hour battery didn,t go well and the
battery didn't hold the voltage above 13 volts anymore and became worse instead of better after each run.
After this experience I modified the device and I use less magnets now (12) but I joined 2 of them togheter because they where
possible to small.
Free spin time is around 8 minutes wooden wheel with a 12 volt power suply feeding the device.
I tried to find a resonance point, I put a bulb 350 mA in series with the 5 amp/H battery and it was lighting brightly at a low resistance , after turning the resistance up it almost went out.
After furter turning the resistance up I saw it come up again but only a little bit and the wheel
just kept running but only after I made the gap between the coil and magnets as small as possible.
After I removed the base diode the lamp burned much brighter but only at this point. I decided to remove the diode this time and replced the potmeter for a fixed resistance (around 1140 ohms).
It took me the first few times around 20 hours to charge the battery (new) but every run it took
less time to charge it and in the end only 14 hours while the capacity to run my load stayed about the same.
I am not sure but I think the capacity of the battery should be increasing so I will be doing something wrong.
After reading all the posts from JB that where all compressed in one pdf I began to understand that less is more in this project so I will give it some more runs but with the base ssg_knagtegl.zipdiode connected just to see the difference.
Can someone give me an idear of how much the capacity of the battery is to go up and what would be the charging time in an ideal setup?
I also am still wondering why it must be a north pole instead of all south pole? does this have to do with the position on the earth?
When I look at this monopole I would think that you could be using both sides of the coil at the same time and get some extra torqe as a bonus but I might be completly wrong.
I did buld a device using boh sides and it seems to be working but than again It will take a lot of time to determine if it works better than the monopole but you will gain nothing if you don't use the mechanical output.
Have some pictures of the quick and dirty setup of the bipole or dipole or duopole or whatever you should call it.
I didn't have fero magnets so I was forced to use neo's but I dempend them by using a pice of iron on them. Its not ideal but it seems to work so far.
Hope anyone can give me some feedback.
Forgive me for my bad english but it is not my native language.
possible to small.
