Hi all!
The Bedini circuits have been around for awhile now but it just a month ago that I finally built my first. I am on the my second version (improving on the first) of the circuit and have stumbled upon a few bumps that I have not found answers to.
My setup:
cart wheel with 4 ceramic 1x1inch magnets
cart wheel is 4.75inches in diameter x 1.5inch thick
coil: 20g and 24g, wound bifilar 554 turns
transistor: 2n3055
resistor: 470ohms (now using 220Ohms in parallel just so I don't need to take out the 470 out of the pcb I made for it)
potentiometer: 5k
battery source: 12v 5ah new
battery charged: 12v 5ah new
core: I-E (for inverter use) thin metal strips as there are no welding rods similar to what is prescribed in the original build
wheel is vertically mounted
Lowest RPM achieved 650 on full resistance of pot
highest RPM achieved 1260 on least resistance of pot
ideal RPM: 400-600 (charges charged battery at fastest time)
repulsion mode
*neon has never lit up
*best achieved drain is 80-90mah at full resistance from pot
*both digital and needle type gauges are used to measure primary batt drain (I tune to lowest amp draw and this is only achieved at lowest pot setting. The in between dips of drain from start and finish pot settings are still higher vs the lowest setting.
What puzzles me:
-I am not able to charge the battery on the charge side to full (source batt runs out first)
-Is my amp drain good enough or should the setup achieve lower drains?
-When I use the source batt, it only lasts about a day until it reaches 10v from 12v
-Shouldn't the batt last for days on this setup without getting drained that much?
-And shouldn't the charged battery get charged before the source batt is drained to 10v?
-Charge time of charged battery is already at 18hours and it is still at 11.24v only.
- How come the NE2 bulb doesn't light or glow at all when run? It only lights up when Source batt is connected and Charged batt is not, but system not spinning.
- Higher RPMs will yield slower charging rates
Is there anyway for me to lessen draw from source batt for it to last longer? Also, shouldn't the charged batt be able to reach full charge much faster than 18hours?
TIA!
My setup:
transistor: 2n3055
potentiometer: 5k
repulsion mode
What puzzles me:
TIA!
