Hello All,
I am quite new to this forum however I have been for the past months working on building a SG Motor to both demonstrate the working principle, the full charging function of the machine and to act as a build for further progressions. Currently, after overcoming the mechanical parts of the build, I am at the tuning stage of the Motor to which I am of the belief that I have correctly tuned the machine, albeit I am not convinced given its performance and the lack of a confirmation method for the machine being in a state of ‘sweet-tune’. I have also worked on the tuning for endless hours trialling different coil-magnet positions and potentiometer resistances to no avail and extreme frustration. I have read over the entirety of the Bedini 3 section(and most of Bedini 2 also) as advised by some of the well-experienced members of this forum in their posts and while it has been reasonably helpful I have found no definitive manner that has helped to solve this problem.
The current state of my machine is as follows:
Wheel is balanced(does not rock back or forth) and spins for 10 mins. I have used numerous washers of 10/20c coin sizes with heaps of tape. While 10mins is not 25 mins I believe it is adequate(and near maximum capacity for this wheel) and the wheel spins with virtually no resistance.
Using 23AWG for Power and 26AWG for Trigger with BOC equivalent to Lincoln R60 Welding Rods
Power Coil Resistance: 2.2Ohms
Trigger Coil Resistance: 4.4Ohms
Typical Bedini SG Circuit with 1kOhm 3W Wirewound Potentiometer (Is this the correct Potentiometer ?)
2x 12V 18Ah Batteries
Distance from Coil-Magnet ~4mm(though not having such a small measuring device on hand I believe its 4-5mm)
Typical Multimeters, Analog Ammeter 1A and Digital Laser Tachometer for RPM
*Annoyingly I have never been able to find Ammeters in Jaycar stores that are more precise
The current problems I face are as follows:
0/ An Initial Question- I have heard of Motor’s being in Attractor or Repulsor mode? Would you agree that my build is in a Attractor mode? It seems like it.
1/ What is the correct gap distance from the coil to the incoming magnet?
I have it at 4mm+ though I have been advised that anywhere between 3.5-5mm is adequate
Throughout the past days I have changed the distance numerous times which has elasticated varying results as one would expect from Laws of Magnetic Forces. At 5+mm the reaction and RPM were far more diminished while at <3mm it was impeding the wheelspin speed. At my current setting I am receiving a adequate amount of wheelspin speed- 274 RPM.
2/ The tuning method and confirmation of sweet-tune resistance
This is the most critical of all. I have found that there is 2 candidates for sweet-tune spots with the present one I am using of 240-250Ohm setting taking 220-250mA input which achieves an RPM of 270+RPM and the lesser other at 120mA. I have found the first at least maintains the best output for the first hour and given the more noticeable characteristics when operating in that pot setting I have focused on finding what I believe is a sweet-tune resistance in a ‘sweet-tune range’.
So why do I believe this is the sweet-tune range and how do I conduct this?
Because it seems to match the characteristics some have described in their posts here and in the Manual pdf.
I start at 250mA and slowly increase the resistance until I reach 245Ohm range and notice the dial suddendly increase in current and waiver greatly. Increasing the resistance slightly further the dial decreases but still waivers. It is at this point that I notice the output voltage raising far higher. Infact, despite a less input current the output voltages in the ‘waiving range’ are higher then those with slighlty larger input current values and slightly less input current values.
This occurs at 240-245Ohm on the Potentiometer and I have interpreted from this repeating on many trials that this is a sweet-tune resistance for the machine.
But is this correct? Am I conducting the correct tuning method? Is this identical or similar to anyone else’s experience?
*While I have read over the recent Instruction Manuals for Beginner and Intermediate I have always generally followed the Bedini 3 Experiment pdf and what I have done follows that pdf.
What is interesting to note is within the 200-250mA range there is negligible changes in RPM so this has been less a factor. Though at or below 200mA it noticeably reduces.
**Note- In addition to the Input Current on the Ammeter and the RPM I also encompass the Output Voltage vs Input Voltage as a measure of it in my view being properly tuned. Is this correct in your opinions?
3/ Lack of continuous output
I have noticed repeatedly that following the first hour of continuous charge that on ALL Potentiometer resistances EVEN where I believe I have attained the sweet-tune state that the Output battery will reach some ceiling(different every time), remain virtually(+/- 2-3 mV) at that output voltage and then after 1-2 hours will reduce in output.
Is this a cause of not being in sweet-tune? Or something related to the coil or circuit properties? Has anyone here experienced this and how did you overcome it?
I have made a video to show the current operation of my build so that you can better assist me with the current problems. In this video I state the questions I have made above with a more thorough set of details on my operation for sweet-tune. Please excuse the poor video quality and the ‘averageness’ of the circuit and parts of the build. Currently, I am seeking just to prove the concept and most of all the self-run operation of the device. My next Bedini SG Motor build will be of far greater quality where I intend to utilise multiple coils and superior circuitry.
The video is on my Ytube Test channel
Link: https://www.youtube.com/watch?v=Sr14...ature=youtu.be
I look forward to your advice, assistance on this so I may be able to move pass the current annoying basic part of this build and into the more critical and interesting parts of this build- the COP tests and Self-Run Cap Dump modes.
I dont have much time but once I have the basic principle done then the possibilities are limitless.
