From the reading I have done, the best way to run the SSG is with a battery as the primary, and at least the same size and type
of the battery being charged.
I have also read that using a power supply that is at least capable of 3 amps is an acceptable way of running the device.
Is there some insight into this that anyone could provide? Why is it better to use the battery?
What if I use a converted PC power supply that is capable of delivering up to 12 or 13 amps at 12V?
Would that be ok? I know that it will run the device, but will it work as well for charging?
If so, why or why not?
As always, thank you all for your valuable information.
