Hello to all,
I would need some help/advise with my current build.
Specs:
28" aluminium bicycle wheel
7x20AWG+1x23AWG prewound coil from teslagenx
7 - MJL21194G transistors bought from https://www.tme.eu/ro/details/mjl211...semiconductor/
14 - 1N4007 diodes bought from https://www.tme.eu/ro/details/1n4007...semiconductor/
7 - 100ohm 1watt 1% resistors
1- 1kohm 1watt potentiometer
1- 12ohm 10 watt resistor on trigger circuit
7 - NEON 2 from https://www.tme.eu/ro/details/neon-2.../brightmaster/
18 - ceramic c8 magnets bought from teslagenx
Presumption: I believe I made all connections correct.
Issue: I believe something is not right..current consumption is around 120mA, wheel spinns at around 90rpm. //consumption should be ~1A and RPM around 300.
From http://www.energyscienceforum.com/sh...ll=1#post31710 I found this information:
"When you connect power to the "run" battery nothing should happen. If the neons light up at this point then the trigger is backwards. If nothing happens then it is as it should be."
I tried this, when I apply power to the input, with no battery connected at the output, the neons light up shortly. Thus I thought I connected the triggers wires wrong, reversed them but the SG doesn't work at all then.
My initial issue was that the neon lights didn't lit up all at the same time, some with high white -violet intensity some with low orange intensity, this was solved by changing the potentiometer value and now all neons light up orange at the same time.
Attached pictures of the device with connections.
Thank you
Specs:
Thank you
